Hello
I have recently upgraded to 5.7.1 after a pending state issue found in 5.7.0. I now have a new issue that gives the following message.
CHECK_NRPE: Invalid packet version received from server.
I do get the result of the query at the end of the message.
I have included the latest profile file from our system.
Regards
Terrence
CHECK_NRPE issue after 5.7.1 upgrade
Re: CHECK_NRPE issue after 5.7.1 upgrade
sounds like your using non-ssl communcations?
we see the same.
our default appears to be to use ssl but since we migrated to a new centos VM, our migrated/imported data started to get ssl errors.
manually running '/usr/local/nagios/libexec/check_nrpe -H HOSTNAME -n' (-n for no-ssl) shows your error even though it does return info.
for us, this is the nail in the coffin for nrpe. deployment & management of nsclient is a pain so i'm currently looking at moving to NCPA.
sorry i cant help, but just letting you know you're not alone!
we see the same.
We had to add -2 to the check to resolve this.
Here is a quote from support:
Regarding, the issue with NRPE checks, please add a -3, for version 3 packets, argument to your check command, and let me know if the error is cleared.
Reference:
https://support.nagios.com/kb/article/n ... s-786.html
Thanks the help,@nickap.
@veehexx, please test with the -2 and -3 options and let us know your results.
Hello
I have added -2 to my NRPE request on the command and it now works.
Thanks nickap for the solution.
Regards
Terrence
Regards
Terrence
thanks to ssax in my 'sucessful migration - mysql issues' thread, our issue was with the DH key length. default seems to be 512, but need 2048 or higher.
since generating 2048 & deploying to clients, both -2 and -3 forced version work.
I am glad your issue has been resolved! Let us know if it is OK to close this topic. Thank you!
Yes, please close this ticket.
Greattpwebb wrote:Yes, please close this ticket.
Locking thread
