Believe Log Server is Full
uinthas
Post by uinthas »
I have neglected my log server for a few months and can no longer log in. When I get to the certificate screen it is real slow to get past, and then when I enter my credentials it just spins and then stops. How might I fix this?
uinthas
Re: Believe Log Server is Full
Post by uinthas »
I was able to find the script that re-sizes the OS partition.
cdienger
Post by cdienger »
In case anyone comes across this in the future, documentation for resizing a VM can be found at https://library.nagios.com/library/prod ... disk-size/.
