Bandwidth errors
benningtonr
Bandwidth errors
Post by benningtonr »
I have ports giving me errors due to bandwidth utilization being above the default threshold. How do I change that, I have some customers getting 40mbs some 60, some 50 etc.
Also i have ports that are disabled but still show as errors.
Thank you
benningtonr
Re: Bandwidth errors
Here are the warnings I am getting about bandwidth
The warning and critical levels were set when you ran the wizard
For the bandwidth levels, if you go into
Configure -> Core Config Manager -> Services -> Modify
The $ARG2$ fiels is the warning level, and the $ARG3$ field is the critical level.
