/check_http: malloc(): memory corruption: 0x00000000010b0120
op-team
Post by op-team »
I have this error when running the plugin check_http v2.2.1
[root@nagios-01: /]# /usr/local/nagios/libexec/check_http -H xx.xx.xx.xx -t 30 -f ok -u /login.html --ssl -p 443
*** glibc detected *** /usr/local/nagios/libexec/check_http: malloc(): memory corruption: 0x0000000000a14120 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x75e5e)[0x7fed23756e5e]
/lib64/libc.so.6(+0x7a41a)[0x7fed2375b41a]
/lib64/libc.so.6(__libc_malloc+0x5c)[0x7fed2375bb1c]
/lib64/libc.so.6(vasprintf+0x39)[0x7fed23750239]
/usr/local/nagios/libexec/check_http[0x407b89]
/usr/local/nagios/libexec/check_http[0x407c46]
/usr/local/nagios/libexec/check_http[0x4063a3]
/usr/local/nagios/libexec/check_http[0x4078e0]
/lib64/libc.so.6(__libc_start_main+0x100)[0x7fed236ffd20]
/usr/local/nagios/libexec/check_http[0x402bd9]
======= Memory map: ========
00400000-00417000 r-xp 00000000 fd:00 649549 /usr/local/nagios/libexec/check_http
00616000-00622000 rw-p 00016000 fd:00 649549 /usr/local/nagios/libexec/check_http
00622000-00626000 rw-p 00000000 00:00 0
009dc000-00a1e000 rw-p 00000000 00:00 0 [heap]
7fed18000000-7fed18021000 rw-p 00000000 00:00 0
7fed18021000-7fed1c000000 ---p 00000000 00:00 0
7fed1c498000-7fed1c4ae000 r-xp 00000000 fd:00 296149 /lib64/libgcc_s-4.4.7-20120601.so.1
7fed1c4ae000-7fed1c6ad000 ---p 00016000 fd:00 296149 /lib64/libgcc_s-4.4.7-20120601.so.1
7fed1c6ad000-7fed1c6ae000 rw-p 00015000 fd:00 296149 /lib64/libgcc_s-4.4.7-20120601.so.1
7fed1c6ae000-7fed22543000 r--p 00000000 fd:00 304618 /usr/lib/locale/locale-archive
7fed22543000-7fed22560000 r-xp 00000000 fd:00 271286 /lib64/libselinux.so.1
7fed22560000-7fed2275f000 ---p 0001d000 fd:00 271286 /lib64/libselinux.so.1
7fed2275f000-7fed22760000 r--p 0001c000 fd:00 271286 /lib64/libselinux.so.1
7fed22760000-7fed22761000 rw-p 0001d000 fd:00 271286 /lib64/libselinux.so.1
7fed22761000-7fed22762000 rw-p 00000000 00:00 0
7fed22762000-7fed22764000 r-xp 00000000 fd:00 264453 /lib64/libkeyutils.so.1.3
7fed22764000-7fed22963000 ---p 00002000 fd:00 264453 /lib64/libkeyutils.so.1.3
7fed22963000-7fed22964000 r--p 00001000 fd:00 264453 /lib64/libkeyutils.so.1.3
7fed22964000-7fed22965000 rw-p 00002000 fd:00 264453 /lib64/libkeyutils.so.1.3
7fed22965000-7fed2296f000 r-xp 00000000 fd:00 271290 /lib64/libkrb5support.so.0.1
7fed2296f000-7fed22b6e000 ---p 0000a000 fd:00 271290 /lib64/libkrb5support.so.0.1
7fed22b6e000-7fed22b6f000 r--p 00009000 fd:00 271290 /lib64/libkrb5support.so.0.1
7fed22b6f000-7fed22b70000 rw-p 0000a000 fd:00 271290 /lib64/libkrb5support.so.0.1
7fed22b70000-7fed22b85000 r-xp 00000000 fd:00 262799 /lib64/libz.so.1.2.3
7fed22b85000-7fed22d84000 ---p 00015000 fd:00 262799 /lib64/libz.so.1.2.3
7fed22d84000-7fed22d85000 r--p 00014000 fd:00 262799 /lib64/libz.so.1.2.3
7fed22d85000-7fed22d86000 rw-p 00015000 fd:00 262799 /lib64/libz.so.1.2.3
7fed22d86000-7fed22daf000 r-xp 00000000 fd:00 264457 /lib64/libk5crypto.so.3.1
7fed22daf000-7fed22faf000 ---p 00029000 fd:00 264457 /lib64/libk5crypto.so.3.1
7fed22faf000-7fed22fb0000 r--p 00029000 fd:00 264457 /lib64/libk5crypto.so.3.1
7fed22fb0000-7fed22fb1000 rw-p 0002a000 fd:00 264457 /lib64/libk5crypto.so.3.1
7fed22fb1000-7fed22fb2000 rw-p 00000000 00:00 0
7fed22fb2000-7fed22fb5000 r-xp 00000000 fd:00 315743 /lib64/libcom_err.so.2.1
7fed22fb5000-7fed231b4000 ---p 00003000 fd:00 315743 /lib64/libcom_err.so.2.1
7fed231b4000-7fed231b5000 r--p 00002000 fd:00 315743 /lib64/libcom_err.so.2.1
7fed231b5000-7fed231b6000 rw-p 00003000 fd:00 315743 /lib64/libcom_err.so.2.1
7fed231b6000-7fed23292000 r-xp 00000000 fd:00 271289 /lib64/libkrb5.so.3.3
7fed23292000-7fed23491000 ---p 000dc000 fd:00 271289 /lib64/libkrb5.so.3.3
7fed23491000-7fed2349b000 r--p 000db000 fd:00 271289 /lib64/libkrb5.so.3.3
7fed2349b000-7fed2349d000 rw-p 000e5000 fd:00 271289 /lib64/libkrb5.so.3.3
7fed2349d000-7fed234de000 r-xp 00000000 fd:00 262637 /lib64/libgssapi_krb5.so.2.2
7fed234de000-7fed236de000 ---p 00041000 fd:00 262637 /lib64/libgssapi_krb5.so.2.2
7fed236de000-7fed236df000 r--p 00041000 fd:00 262637 /lib64/libgssapi_krb5.so.2.2
7fed236df000-7fed236e1000 rw-p 00042000 fd:00 262637 /lib64/libgssapi_krb5.so.2.2
7fed236e1000-7fed2386c000 r-xp 00000000 fd:00 262202 /lib64/libc-2.12.so
7fed2386c000-7fed23a6b000 ---p 0018b000 fd:00 262202 /lib64/libc-2.12.so
7fed23a6b000-7fed23a6f000 r--p 0018a000 fd:00 262202 /lib64/libc-2.12.so
7fed23a6f000-7fed23a71000 rw-p 0018e000 fd:00 262202 /lib64/libc-2.12.so
7fed23a71000-7fed23a75000 rw-p 00000000 00:00 0
7fed23a75000-7fed23a77000 r-xp 00000000 fd:00 298436 /lib64/libdl-2.12.so
7fed23a77000-7fed23c77000 ---p 00002000 fd:00 298436 /lib64/libdl-2.12.so
7fed23c77000-7fed23c78000 r--p 00002000 fd:00 298436 /lib64/libdl-2.12.so
7fed23c78000-7fed23c79000 rw-p 00003000 fd:00 298436 /lib64/libdl-2.12.so
7fed23c79000-7fed23c90000 r-xp 00000000 fd:00 262226 /lib64/libpthread-2.12.so
7fed23c90000-7fed23e90000 ---p 00017000 fd:00 262226 /lib64/libpthread-2.12.so
7fed23e90000-7fed23e91000 r--p 00017000 fd:00 262226 /lib64/libpthread-2.12.so
7fed23e91000-7fed23e92000 rw-p 00018000 fd:00 262226 /lib64/libpthread-2.12.so
7fed23e92000-7fed23e96000 rw-p 00000000 00:00 0
7fed23e96000-7fed24050000 r-xp 00000000 fd:00 264416 /usr/lib64/libcrypto.so.1.0.1e
7fed24050000-7fed24250000 ---p 001ba000 fd:00 264416 /usr/lib64/libcrypto.so.1.0.1e
7fed24250000-7fed2426b000 r--p 001ba000 fd:00 264416 /usr/lib64/libcrypto.so.1.0.1e
7fed2426b000-7fed24277000 rw-p 001d5000 fd:00 264416 /usr/lib64/libcrypto.so.1.0.1e
7fed24277000-7fed2427b000 rw-p 00000000 00:00 0 Aborted
Any idea about a solution? Thanks
cdienger
Re: /check_http: malloc(): memory corruption: 0x00000000010b
Post by cdienger »
Possibly something with the secure option. Did you compile with ssl support? Does a check_http command work if you test with a http (not https) site?
op-team
Post by op-team »
The issue disappeared when running the recent version of the plugin: check_http v2.3.3
B.Regards
op-team wrote:Hi,
B.Regards
Great! Glad to hear it is resolved!
Locking thread
