dependency error during installation
mon-team
Post by mon-team »
i'm trying to install Nagios XI 5.7.1 on a new fresh CentOS 7.8.
The installation fails at the first step on the script checking the pre-requisite.
In some cases the installed libraries are newer that the required one, in other cases they differ for a very very little minor release...
This happens using the 'nagiosxi-deps' repository:
Requires: glibc = 2.17-292.el7
Installed: glibc-2.17-307.el7.1.i686
Requires: php-cli(x86-64) = 5.4.16-48.el7
Available: php-cli-5.4.16-21.el7.x86_64 (rhel-x86_64-server-7)
Do you have any suggestion? The script says to use the --skip-broken option, is it safe? I have to manaully edit the 1-prereqs script to add the option or where can i pass it?
regards
Francesco
ssax
Dreams In Code
Re: dependency error during installation
Post by ssax »
I wouldn't skip-broken as it can cause issues, there's a reason it's failing. Please send us the full upgrade.log file so we can debug further.
Please PM me a copy of your profile as well, you can download it from Admin > System Profile > Download Profile button.
Thank you!
