Unable to authenticate: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed (unable to get local issuer certificate)
I have stoodup a new test Nagiosxi Server on CentOS7
When I try and Access the Active Direrctory Users and Computers I get the above error message
The same config works fine on our Red Hat 6 Server
I have attached Screenshots of the
Authentication Server Configuration and the Certificate Authority Management
On the D-OPS-03 Domain Controller the following setting is applied
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NTDS\Parameters]
"ldapserverintegrity"=dword:00000002
From what I see it looks like it is something to do with the Certificate.
The Server D-OPS-03 is our CA Server
If I change the setting "ldapserverintegrity"=dword:00000002 to 0
and set the Security Setting to None under the Authentication Server then the connection works fine
Re: Unable to authenticate: error:14090086
What are the permissions set to on the ldap directory when you run "ls -alhR /etc/openldap" ? We'd expect them to look something like:
ls -alhR /etc/openldap/
/etc/openldap/:
total 20K
drwxrwxr-x. 4 apache nagios 4.0K Jun 17 09:53 .
drwxr-xr-x. 85 root root 4.0K Jun 17 15:29 ..
drwxrwxr-x 2 apache nagios 4.0K Jun 17 09:53 cacerts
drwxrwxr-x. 2 apache nagios 4.0K Mar 22 2017 certs
-rw-rw-r-- 1 apache nagios 317 Jun 17 09:53 ldap.conf
/etc/openldap/cacerts:
total 8.0K
drwxrwxr-x 2 apache nagios 4.0K Jun 17 09:53 .
drwxrwxr-x. 4 apache nagios 4.0K Jun 17 09:53 ..
/etc/openldap/certs:
total 72K
drwxrwxr-x. 2 apache nagios 4.0K Mar 22 2017 .
-rw-r--r--. 1 root root 64K May 6 2015 cert8.db
-rw-r--r--. 1 root root 16K May 6 2015 key3.db
-r--------. 1 root root 45 May 6 2015 password
-rw-r--r--. 1 root root 16K May 6 2015 secmod.dbAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Hi
All the permissions look ok
[root@dwylbopngios02 openssl]# ls -alhR /etc/openldap
/etc/openldap:
total 20K
drwxrwxr-x. 4 apache nagios 72 Jun 19 03:18 .
drwxr-xr-x. 105 root root 8.0K Jun 18 11:18 ..
drwxrwxr-x 2 apache nagios 29 Jun 19 03:37 cacerts
drwxrwxr-x. 2 apache nagios 120 Jun 19 03:37 certs
-rw-rw-r-- 1 apache nagios 400 Jun 18 09:01 ldap.conf
-rw-rw-r-- 1 apache nagios 400 Jun 18 09:01 ldap.conf.bak
total 0
drwxrwxr-x 2 apache nagios 29 Jun 19 03:37 .
drwxrwxr-x. 4 apache nagios 72 Jun 19 03:18 ..
lrwxrwxrwx 1 apache apache 37 Jun 18 09:51 5eeb716e1945c.0 -> /etc/openldap/certs/5eeb716e1945c.pem
total 76K
drwxrwxr-x. 2 apache nagios 120 Jun 19 03:37 .
-rw-r--r-- 1 apache apache 2.0K Jun 18 09:51 5eeb716e1945c.crt
-rw-r--r-- 1 apache apache 5.8K Jun 18 09:51 5eeb716e1945c.pem
-rw-r--r--. 1 root root 64K May 3 2018 cert8.db
-rw-r--r--. 1 root root 16K May 3 2018 key3.db
-r--------. 1 root root 45 May 3 2018 password
-rw-r--r--. 1 root root 16K May 3 2018 secmod.db
/etc/openldap:
total 20K
total 0
total 76K
It's having diffculty getting or matching the cert. Let's get a tcpdump so we can confirm the communication and the ceritificate. Do this on the XI comamnd line:
Where w.x.y.z is the IP address of the DC. Let this run just long enough to try to authenticate and reproduce the error then use CTRL+C to stop it. Please PM me the output.pcap file this creates.
yum -y install tcpdump (Cent/RHEL)
apt-get install tcpdump (Deb/Ubuntu)Code: Select all
tcpdump -s 0 -i any host w.x.y.z -w output.pcapAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Hi
PM message sent with output.pcap file
The file doesn't appear to have made it. Try compressing it and changing the extension to .zip.
