Hi Team,
We have tried to add AIX server 7.2 to Nagioxi using check_by_ssh plugin. But we are getting the below permission issue.
Error
[nagios@fujams01 ~]$ /usr/local/nagios/libexec/check_by_ssh -H drcoreflsh01 -C /usr/local/nagios/libexec/check_disk
Remote command execution failed: ksh: /usr/local/nagios/libexec/check_disk: 0403-006 Execute permission denied.
Please check and advise on this issue.
Followed the same document mentioned below.
https://assets.nagios.com/downloads/nag ... ng_SSH.pdf
Note: We are able to do passwordless authentication to remote server and the command /usr/local/nagios/libexec/check_by_ssh -H remoteip -C uptime works fine.
Remote AIX Server file permissions
root@drcoreflsh01:/home/nagios # ls -ltr
total 1656
-rwxrwxr-x 1 nagios staff 157552 Feb 25 2019 check_users
-rwxrwxr-x 1 nagios staff 223992 Feb 25 2019 check_procs
-rwxrwxrwx 1 nagios staff 227160 Feb 25 2019 check_disk
-rwxrwxrwx 1 nagios staff 214424 Feb 25 2019 check_by_ssh
-rwxr----- 1 nagios staff 254 Jun 20 09:11 .profile
drwx------ 2 nagios staff 256 Jun 20 09:17 .ssh
-rwxr-xr-x 1 nagios staff 2835 Jun 20 14:14 check_AIX_disk.sh
-rw------- 1 nagios staff 209 Jun 20 14:31 .bash_history
-rw------- 1 nagios staff 418 Jun 20 14:31 .sh_history
AIX server 7.2 permission denied error nagiosxi
Re: AIX server 7.2 permission denied error nagiosxi
You provided a directory listing of /home/nagios but the plugin would be found in /usr/local/nagios/libexec/check_disk on the AIX machine. Please get a directory listing of that. I'd also like to see a copy of the /usr/local/nagios/libexec/check_disk as well. It looks like it is trying to run ksh - is this shell available on the AIX system? A check_disk script using bash can be found at https://support.nagios.com/forum/viewto ... 16&t=40948 if you'd like to test that.
Please find below the file listings under libexec directory.
root@drcoreflsh01:/usr/local/nagios/libexec # ls -ltr
total 1968
-rwxrwxr-x 1 nagios staff 227160 Feb 25 2019 check_disk_old_23june2020
-rwxrwxr-x 1 nagios staff 214424 Feb 25 2019 check_by_ssh
-rw-r--r-- 1 root system 153544 Mar 17 10:14 dos2unix-7.4.0-1.aix5.1.ppc.rpm
-rwxr-xr-x 1 nagios staff 6016 Jun 23 10:46 check_disk
-rwxr-xr-x 1 nagios staff 2878 Jun 23 11:19 check_cpu
-rwxr-xr-x 1 nagios staff 4893 Jun 23 11:35 check_filesystems
We have copied these files directly from nagios xi server, it was available by default in nagios xi server. Please see below the file format used.
root@drcoreflsh01:/usr/local/nagios/libexec # file check_users
check_users: ELF 64-bit LSB version 1 executable
root@drcoreflsh01:/usr/local/nagios/libexec # file check_procs
check_procs: ELF 64-bit LSB version 1 executable
root@drcoreflsh01:/usr/local/nagios/libexec # file check_disk_old_23june2020
check_disk_old_23june2020: ELF 64-bit LSB version 1 executable
root@drcoreflsh01:/usr/local/nagios/libexec # file check_by_ssh
check_by_ssh: ELF 64-bit LSB version 1 executable
Default shell used is ksh for all users
root@drcoreflsh01:/usr/local/nagios/libexec # lsuser -f root | grep -i shell
shell=/usr/bin/ksh
root@drcoreflsh01:/usr/local/nagios/libexec # lsuser -f nagios | grep -i shell
shell=/usr/bin/ksh
We have used the check_disk script using bash from viewtopic.php?f=16&t=40948 . It works fine and provided us the expected output.
check_disk: shell script
[nagios@fujams01 ~]$ /usr/local/nagios/libexec/check_by_ssh -H drcoreflsh01 -C '/usr/local/nagios/libexec/check_disk 80 85 /opt'
OK: '/opt' is at 33% capacity, total 4.0GB, used 1.3GB (32.9%), free 2.7GB (67.1%) | 'used space'=2760440B;6710886;7130316;0;8388608 'used space (pct.)'=32.9%;80;85;0;100
Do we have similar type of plugins which can provide cpu usage, users,procs etc.
Please suggest
total 1968
shell=/usr/bin/ksh
shell=/usr/bin/ksh
Please suggest
The plugins being copied over is going to be the problem. The plugins were compiled for a different system. You'll need to compile them for/on the AIX system.
The source can be downloaded from https://nagios-plugins.org/.
Another option is to use scripts instead of compiling binaries.
The exchange will have some plugins:
https://exchange.nagios.org/directory/P ... ystems/AIX
as does the NRPE agent(https://assets.nagios.com/downloads/nag ... ent.tar.gz). I've attached the plugins that come with this agent.
Issue sorted out. Please close the thread
Thank you very much for your inputs.
Great!mejokj wrote:Issue sorted out. Please close the thread
Locking thread
