Hello everyone,
I am trying to see the status of my last backups of bareos with nagios, I have downloaded this plugins and what I created in:/usr/local/nagios/libexec/
I have given him the necessary permits and I have assigned him to nagios.
but there is no information on how to test the plugins, someone could tell me how to test the plugins. If someone uses other plugins and knows how to use it, tell me something.
My configuration
host_name Backups-Bareos
service_description Check Bacula Last Backup
contact_groups admins
check_command check_bacula_last_backup!bareos-fd
notifications_enabled 1
command_name check_bacula_last_backup
command_line $USER1$/check_bacula_lastbackup.pl -client $ARG1$
My result:
CRITICAL 06-21-2020 17:01:21 0d 0h 47m 34s 3/3 (No output on stdout) stderr: /usr/local/nagios/libexec/check_bacula_lastbackup.pl: 10: /usr/local/nagios/libexec/check_bacula_lastbackup.pl: use: not found
plugin links:
https://exchange.nagios.org/directory/P ... 2806657786
Thank you
please help how to test: check_bacula_lastbackup.pl
Re: please help how to test: check_bacula_lastbackup.pl
What do you get if you just run this from the CLI
/usr/local/nagios/libexec/check_bacula_lastbackup.pl -client bareos-fdRe: please help how to test: check_bacula_lastbackup.pl
Hallo,
when running the plugins this is what comes out:
./check_bacula_lastbackup.pl -client bareos-fd
sh: 1: /usr/sbin/bconsole: not found
CRITICAL: Unable to find a valid backup for bareos-fd
