Exporting data from Nagios
SAABSupport
We want to export the data from a monitoring service into a file, that updates if the values change, so that we can use the data in the file elsewhere in other programs.
Re: Exporting data from Nagios
It's not clear what data you want to export exactly but you may want to check out the API by pointing your browser to http://xi_ip/nagiosxi/help/. You can use the API to export check results as well as configuration.
