I want to monitor a Linux host with OS as RHEL 4.x.
Kindly help me to install NRPE agent on RHEL 4.x Linux Host.
NRPE - Installation Process for RHEL 4.x
s.diwakar1
Thanks & Regards,
Diwakar Sharma
Diwakar Sharma
benjaminsmith
Re: NRPE - Installation Process for RHEL 4.x
The latest version has not been tested on this operating system,but the best option would recommend trying to install from source using the following guide.
NRPE - How To Install NRPE v3 From Source
You can get previous releases of NRPE on the Git Hub Page:
https://github.com/NagiosEnterprises/nrpe/releases
Good luck!
Good luck!
