I have a problem with SNMP and nagios, i try to check a IBM x3850 X5 server with the following command,
I get/usr/local/nagios/libexec/check_snmp -m /usr/share/snmp/mibs/imm.mib -H 172.30.25.21 -C community_1 -p 161 -o .1.3.6.1.4.1.2.3.51.3.1.4.1
External command error: Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: IMM-MIB::systemHealthStatThe MIB is tested on Windows with reasoning MIB browser with the same parameters, community, ports, IP etc
I can do a walk from Nagios
and the response is something likesnmpwalk -v1 -c community_1 172.30.25.21
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.8072.3.2.10
iso.3.6.1.2.1.1.3.0 = Timeticks: (6507012) 18:04:30.12
Starts with “iso”…don’t really know why, also the OID i see on reasoning browser are not in the MIB file, how can that be possible?
I must do this with nagios and there are other alarms with this plugin that are working well,
Can anyone help¿
