NCPA s390 Hardware
Maxwellb99
NCPA s390 Hardware
Post by Maxwellb99 »
Hi Nagios,
Do you support NCPA for s390x Hardware (Mainframe)? I'm being told "We run the SLES EDI guests on s390x hardware (mainframe), not Intel (x86_64). I do not see any indication that Nagios supports s390x. The rpms we would need would be *.s390x.rpm."
Max R
ssax
Dreams In Code
Re: NCPA s390 Hardware
Post by ssax »
NCPA doesn't currently support that architecture. You can try compiling from source but I'm not sure it would work given we don't compile or have access to that architecture:
https://github.com/NagiosEnterprises/ncpa
You can use the SSH to monitor them if it supports SSH:
https://assets.nagios.com/downloads/nagiosxi/docs/Monitoring_Hosts_Using_SSH.pdf
If you're able to enable SNMP you can use that as an alternative as well.
