Hello XI Support
What to do when NCPA does not see Linux mounts that are there (NRPE sees them on the same host)
- we are trying to switch all of our SUSE servers from NRPE to NCPA because we are having troubles with installing NRPE on SUSE and it overloads some hosts with many connectivity errors
Thank you
NCPA does not see mounts that are there
Re: NCPA does not see mounts that are there
Is it an NFS mount?
I'm wondering if you're hitting this:
https://github.com/NagiosEnterprises/ncpa/issues/643
If it's not NFS, check in your ncpa.cfg on the remote system to make sure it's not listed in the exclude_fs_types line:
exclude_fs_types = aufs,autofs,binfmt_misc,cifs,cgroup,configfs,debugfs,devpts,devtmpfs,encryptfs,efivarfs,fuse,fusectl,hugetlbfs,mqueue,nfs,overlayfs,proc,pstore,rpc_pipefs,securityfs,selinuxfs,smb,sysfs,tmpfs,tracefsRe: NCPA does not see mounts that are there
ssax wrote:Is it an NFS mount?
This worked, thank you
Please close the case
Greatdlukinski wrote:ssax wrote:Is it an NFS mount?
Locking thread
