We are using nagios for host monitoring .We want to increase a table column size .As we are getting truncated response from one of the api of nagios :-
http://nagios-stage.logistics.com/nagio ... h&pretty=1
"check_command":"manh_check_file_ageing!/manh/share/integration/WebMethods/FilePolling/JSON/SC_PurchaseOrder/monitoring,/manh/share/integration/WebMethods/FilePolling/JSON/SC_LocationCount/monitoring,/manh/share/integration/WebMethods/FilePolling/JSON/SC_LocationMask/moni"
after hitting above url we are getting truncated data for check_command ,please let us now which table and column size we need to increase so that we will not get truncated result
NAGIOS DB
benjaminsmith
Re: NAGIOS DB
Hi @manhuser,
It looks like there is a really long check command, please run the following to SQL command and let me know if the issue is resolved.
If the issue persists, please PM your system profile so we can review the logs. Thanks, Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket, and then reply to this post to bring it up in the queue.
mysql -h 127.0.0.1 -uroot -pnagiosxi nagios -e "ALTER TABLE nagios_servicestatus MODIFY check_command TEXT NOT NULL DEFAULT '';"
