One host unable to report data to Nagios XI
sathevaner
Post by sathevaner »
We have one host that has refused to report itself as "Up" since October 2019. The error we have been unable to reproduce is, "CRITICAL - (IP address redacted): Time to live exceeded in transit @ (IP address redacted). rta nan, lost 100%"
How do I troubleshoot this?
benjaminsmith
Re: One host unable to report data to Nagios XI
Post by benjaminsmith »
Let's start by opening up a terminal and pinging the host to see if you get a reply. For example,
ping -c 5 <ip address>
If that works but the check is failing in Nagios XI, please post the full check command to the thread so we can review it. The following guide has instructions on how to find the check command and test it from the command line in XI.
Nagios XI - How To Test Check Commands From The Command-line
Also, not sure if this is the reason or not, but ICMP is disabled by default on some servers and a ping check will fail even though the host is up.
See:
https://serverfault.com/questions/51173 ... 2-instance
sathevaner
Benjamin,
This is what's happening on the Nagios XI server:
[root@host libexec]# ./check_icmp -H (IP address redacted) -w 3000.0,80% -c 5000.00,100%,-p 8
CRITICAL - (IP address redacted) lost 0% >= 0% :: 8: rta nan, lost 100%|(IP address redacted)rta=11.014ms;3000.000;5000.000;0; (IP address redacted)pl=0%;0;0;0;100 (IP address redacted)rtmax=12.877ms;;;; 10.71.247.1rtmin=9.833ms;;;; 8rta=0.000ms;3000.000;5000.000;0; 8pl=100%;0;0;0;100 8rtmax=0.000ms;;;; 8rtmin=0.000ms;;;;
and doing a ping to the same host is successful:
[root@host libexec]# ping -c 5 (IP address redacted)
PING (IP address redacted) ((IP address redacted)) 56(84) bytes of data.
64 bytes from (IP address redacted): icmp_seq=1 ttl=252 time=10.4 ms
64 bytes from (IP address redacted): icmp_seq=2 ttl=252 time=9.40 ms
64 bytes from (IP address redacted): icmp_seq=3 ttl=252 time=9.94 ms
64 bytes from (IP address redacted): icmp_seq=4 ttl=252 time=10.4 ms
64 bytes from (IP address redacted): icmp_seq=5 ttl=252 time=10.3 ms
Please advise.
benjaminsmith
Looking over the check command, there is a slight error in the syntax, it should be as follows:
./check_icmp -H (IP address redacted) -w 3000.0,80% -c 5000.00,100% -p 8
That is, without the comma between 100% and -p. Test that out on the command line, then go to the CCM in Nagios XI and verify the syntax on the check command, and let me know if the issue is resolved.
Reference:
Using The Core Config Manager For Host Management
sathevaner
This thread may now be locked. Apparently all that was needed as "Force an immediate check" despite being up this whole time.
benjaminsmith
Thanks for following up. If the issue comes back, feel free to open another thread.
Benjamin
