Wanted to make the maps prettier
Shivaramakrishnan
Post by Shivaramakrishnan »
Hi
I wanted to know is there any way to customize the maps in Nagios?
I was looking for something like
An Icon with the host name and its status.And if we select that icon,it should drill down for its services detail. "See attached"
Is there any way to accomplish this?Is there any plugin
I wanted to make the maps look more prettier.Any suggestions would be appreciated.
Something like this would be ideal
agriffin
Re: Wanted to make the maps prettier
Post by agriffin »
Check out NagVis. It's pretty customizable and I think the default map is laid out how you specified.
