Can we capture the alerts in a file.
For every alert generated in Nagios we need the alert message to be created in a seperate file in a folder location.
Kindly advise.
Thanks.
Capture Alerts in a file
benjaminsmith
Re: Capture Alerts in a file
HI,
One option is the reports, this information is available (e.g. State History, Alert History) and can be sent as a CSV file on a regular basis using the scheduled reporting feature.
You can also automate this with some scripting. For example, you can write this data to a log file using a custom event handler or you can parse the nagios.logs on a schedulable basis and write out the required data to a separate log.
Introduction to Event Handlers
Log Files:'
Hope that helps, and let me know if you have any questions.
Log Files:'
/usr/local/nagios/var/archives
/usr/local/nagios/var/nagios.log
This would be easiest to use the Global Event Handlers in XI if you want to do it for every all hosts/services
