Hi
After updating the version of Nagios XI the apache error_log file shows the following:
[Tue Jul 07 13:02:25.595302 2020] [:error] [pid 26243] [client 10.8.198.57:54634] PHP Notice: Call made to exec_sql_query() when DB handler does not exist\n#0 exec_sql_query(nagiosxi, SELECT * FROM xi_options WHERE name='active_poller_interval', ) called at [/usr/local/nagiosxi/html/includes/utils.inc.php:1037]\n#1 get_option(active_poller_interval) called at [/usr/local/nagiosxi/html/includes/dashlets/bpi/bpi.inc.php:41]\n#2 bpi_dashlet_init() called at [/usr/local/nagiosxi/html/includes/dashlets/bpi/bpi.inc.php:9]\n#3 include_once(/usr/local/nagiosxi/html/includes/dashlets/bpi/bpi.inc.php) called at [/usr/local/nagiosxi/html/includes/dashlets.inc.php:21]\n#4 require_once(/usr/local/nagiosxi/html/includes/dashlets.inc.php) called at [/usr/local/nagiosxi/html/includes/common.inc.php:12]\n#5 require_once(/usr/local/nagiosxi/html/includes/common.inc.php) called at [/usr/local/nagiosxi/html/includes/components/nocscreen/nocscreenapi.php:7]\n in /usr/local/nagiosxi/html/includes/db.inc.php on line 517, referer: https://SERVER/nagiosxi/includes/compon ... en/noc.php
How can I eliminate these errors?
Regards
PHP Notice after update 5.5.11 to 5.6.14
Re: PHP Notice after update 5.5.11 to 5.6.14
Please PM me a copy of your profile, you can download it from Admin > System Profile > Download Profile button.
Additionally, please send the output of these commands (as root):
- NOTE: You may need to adjust the -h 127.0.0.1, the -uroot, and -pnagiosxi in the first command if your DB is offloaded to another server and/or you've changed the root mysql password
Then run this command:
If it outputs the number 2, run the command below as well and include the output, if it outputs anything other than 2 - don't run the command. (some XI systems use both mysql and postgresql if they were install prior to XI 5.0 and then upgraded from there).
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --tableCode: Select all
grep mysql /usr/local/nagiosxi/html/config.inc.php | wc -lCode: Select all
echo "SELECT relname as Table, pg_size_pretty(pg_total_relation_size(relid)) As Size, pg_size_pretty(pg_total_relation_size(relid) - pg_relation_size(relid)) as ExternalSize FROM pg_catalog.pg_statio_user_tables ORDER BY pg_total_relation_size(relid) DESC;" | psql nagiosxi nagiosxiRe: PHP Notice after update 5.5.11 to 5.6.14
Hi
I sent you by MP the system information.
Result is 3
grep mysql /usr/local/nagiosxi/html/config.inc.php | wc -l+--------------------------------------------+------------+
| Table | Size in MB |
| nagios_acknowledgements | 0.00 |
| nagios_commands | 0.04 |
| nagios_commenthistory | 0.12 |
| nagios_comments | 0.00 |
| nagios_configfiles | 0.00 |
| nagios_configfilevariables | 0.01 |
| nagios_conninfo | 0.22 |
| nagios_contact_addresses | 0.00 |
| nagios_contact_notificationcommands | 0.02 |
| nagios_contactgroup_members | 0.00 |
| nagios_contactgroups | 0.00 |
| nagios_contactnotificationmethods | 0.11 |
| nagios_contactnotifications | 0.12 |
| nagios_contacts | 0.01 |
| nagios_contactstatus | 0.00 |
| nagios_customvariables | 0.01 |
| nagios_customvariablestatus | 0.01 |
| nagios_dbversion | 0.00 |
| nagios_downtimehistory | 0.02 |
| nagios_eventhandlers | 0.00 |
| nagios_externalcommands | 0.01 |
| nagios_flappinghistory | 0.36 |
| nagios_host_contactgroups | 0.00 |
| nagios_host_contacts | 0.00 |
| nagios_host_parenthosts | 0.00 |
| nagios_hostchecks | 0.00 |
| nagios_hostdependencies | 0.00 |
| nagios_hostescalation_contactgroups | 0.00 |
| nagios_hostescalation_contacts | 0.00 |
| nagios_hostescalations | 0.00 |
| nagios_hostgroup_members | 0.00 |
| nagios_hostgroups | 0.00 |
| nagios_hosts | 0.01 |
| nagios_hoststatus | 0.02 |
| nagios_instances | 0.00 |
| nagios_logentries | 15.58 |
| nagios_notifications | 0.19 |
| nagios_objects | 1.04 |
| nagios_processevents | 0.17 |
| nagios_programstatus | 0.00 |
| nagios_runtimevariables | 0.00 |
| nagios_scheduleddowntime | 0.00 |
| nagios_service_contactgroups | 0.00 |
| nagios_service_contacts | 0.01 |
| nagios_service_parentservices | 0.00 |
| nagios_servicechecks | 0.00 |
| nagios_servicedependencies | 0.00 |
| nagios_serviceescalation_contactgroups | 0.00 |
| nagios_serviceescalation_contacts | 0.00 |
| nagios_serviceescalations | 0.00 |
| nagios_servicegroup_members | 0.00 |
| nagios_servicegroups | 0.00 |
| nagios_services | 0.01 |
| nagios_servicestatus | 0.04 |
| nagios_statehistory | 4.15 |
| nagios_systemcommands | 0.05 |
| nagios_timedeventqueue | 0.00 |
| nagios_timedevents | 0.00 |
| nagios_timeperiod_timeranges | 0.02 |
| nagios_timeperiods | 0.01 |
| tbl_command | 0.06 |
| tbl_contact | 0.02 |
| tbl_contactgroup | 0.01 |
| tbl_contacttemplate | 0.01 |
| tbl_domain | 0.01 |
| tbl_host | 0.01 |
| tbl_hostdependency | 0.00 |
| tbl_hostescalation | 0.00 |
| tbl_hostextinfo | 0.00 |
| tbl_hostgroup | 0.01 |
| tbl_hosttemplate | 0.02 |
| tbl_info | 0.13 |
| tbl_lnkContactToCommandHost | 0.00 |
| tbl_lnkContactToCommandService | 0.00 |
| tbl_lnkContactToContactgroup | 0.00 |
| tbl_lnkContactToContacttemplate | 0.01 |
| tbl_lnkContactToVariabledefinition | 0.00 |
| tbl_lnkContactgroupToContact | 0.00 |
| tbl_lnkContactgroupToContactgroup | 0.00 |
| tbl_lnkContacttemplateToCommandHost | 0.00 |
| tbl_lnkContacttemplateToCommandService | 0.00 |
| tbl_lnkContacttemplateToContactgroup | 0.00 |
| tbl_lnkContacttemplateToContacttemplate | 0.00 |
| tbl_lnkContacttemplateToVariabledefinition | 0.00 |
| tbl_lnkHostToContact | 0.00 |
| tbl_lnkHostToContactgroup | 0.00 |
| tbl_lnkHostToHost | 0.00 |
| tbl_lnkHostToHostgroup | 0.00 |
| tbl_lnkHostToHosttemplate | 0.00 |
| tbl_lnkHostToVariabledefinition | 0.00 |
| tbl_lnkHostdependencyToHost_DH | 0.00 |
| tbl_lnkHostdependencyToHost_H | 0.00 |
| tbl_lnkHostdependencyToHostgroup_DH | 0.00 |
| tbl_lnkHostdependencyToHostgroup_H | 0.00 |
| tbl_lnkHostescalationToContact | 0.00 |
| tbl_lnkHostescalationToContactgroup | 0.00 |
| tbl_lnkHostescalationToHost | 0.00 |
| tbl_lnkHostescalationToHostgroup | 0.00 |
| tbl_lnkHostgroupToHost | 0.00 |
| tbl_lnkHostgroupToHostgroup | 0.00 |
| tbl_lnkHosttemplateToContact | 0.00 |
| tbl_lnkHosttemplateToContactgroup | 0.00 |
| tbl_lnkHosttemplateToHost | 0.00 |
| tbl_lnkHosttemplateToHostgroup | 0.00 |
| tbl_lnkHosttemplateToHosttemplate | 0.00 |
| tbl_lnkHosttemplateToVariabledefinition | 0.00 |
| tbl_lnkServiceToContact | 0.00 |
| tbl_lnkServiceToContactgroup | 0.00 |
| tbl_lnkServiceToHost | 0.00 |
| tbl_lnkServiceToHostgroup | 0.00 |
| tbl_lnkServiceToServicegroup | 0.00 |
| tbl_lnkServiceToServicetemplate | 0.00 |
| tbl_lnkServiceToVariabledefinition | 0.00 |
| tbl_lnkServicedependencyToHost_DH | 0.00 |
| tbl_lnkServicedependencyToHost_H | 0.00 |
| tbl_lnkServicedependencyToHostgroup_DH | 0.00 |
| tbl_lnkServicedependencyToHostgroup_H | 0.00 |
| tbl_lnkServicedependencyToService_DS | 0.00 |
| tbl_lnkServicedependencyToService_S | 0.00 |
| tbl_lnkServicedependencyToServicegroup_DS | 0.02 |
| tbl_lnkServicedependencyToServicegroup_S | 0.02 |
| tbl_lnkServiceescalationToContact | 0.00 |
| tbl_lnkServiceescalationToContactgroup | 0.00 |
| tbl_lnkServiceescalationToHost | 0.00 |
| tbl_lnkServiceescalationToHostgroup | 0.00 |
| tbl_lnkServiceescalationToService | 0.00 |
| tbl_lnkServiceescalationToServicegroup | 0.02 |
| tbl_lnkServicegroupToService | 0.00 |
| tbl_lnkServicegroupToServicegroup | 0.00 |
| tbl_lnkServicetemplateToContact | 0.00 |
| tbl_lnkServicetemplateToContactgroup | 0.00 |
| tbl_lnkServicetemplateToHost | 0.00 |
| tbl_lnkServicetemplateToHostgroup | 0.00 |
| tbl_lnkServicetemplateToServicegroup | 0.00 |
| tbl_lnkServicetemplateToServicetemplate | 0.01 |
| tbl_lnkServicetemplateToVariabledefinition | 0.00 |
| tbl_lnkTimeperiodToTimeperiod | 0.00 |
| tbl_logbook | 0.00 |
| tbl_mainmenu | 0.00 |
| tbl_permission | 0.02 |
| tbl_permission_inactive | 0.02 |
| tbl_service | 0.01 |
| tbl_servicedependency | 0.00 |
| tbl_serviceescalation | 0.00 |
| tbl_serviceextinfo | 0.00 |
| tbl_servicegroup | 0.01 |
| tbl_servicetemplate | 0.03 |
| tbl_session | 0.00 |
| tbl_session_locks | 0.00 |
| tbl_settings | 0.00 |
| tbl_submenu | 0.00 |
| tbl_timedefinition | 0.02 |
| tbl_timeperiod | 0.01 |
| tbl_user | 0.01 |
| tbl_variabledefinition | 0.00 |
| xi_auditlog | 0.41 |
| xi_auth_tokens | 0.03 |
| xi_cmp_trapdata | 0.03 |
| xi_cmp_trapdata_log | 0.03 |
| xi_commands | 0.00 |
| xi_eventqueue | 0.02 |
| xi_events | 0.00 |
| xi_incidents | 0.02 |
| xi_meta | 0.01 |
| xi_mibs | 0.05 |
| xi_options | 0.04 |
| xi_sessions | 0.03 |
| xi_sysstat | 0.01 |
| xi_usermeta | 1.00 |
| xi_users | 0.06 |
Result is 3
That information looks good, I replied to your PM, I will need the profile.zip to look at your logs.
Actually, I think this is likely because you installed the fusion BPI dashlet on XI (there is no XI BPI dashlet), please run this command and it will likely fix your issue:
rm -rf /usr/local/nagiosxi/html/includes/dashlets/bpi
