Nagios 4.4.5 fresh install not working on Solaris 11.4
chedaille
Post by chedaille »
I have just installed Nagios Core 4.4.5 on a Solaris 11 system with the following Software configuration:
SunOS solaris11 5.11 11.4.0.15.0 i86pc i386 i86pc
GCC 7.3.0
GD 2.2.5
PHP 5.6.36
Apache 2.4.33
Nagios 4.4.5
To perform the installation, I followed the official instructions from Nagios website:
https://support.nagios.com/kb/article/n ... ml#Solaris
After a fresh install, I am now facing 2 main issues that are preventing to use Nagios and deploy it in production:
1) When login into Nagios with nagiosadmin user, the error "Not running" is displayed.
See attached screenshot: https://prnt.sc/te8j9k
However, the services is correctly running:
STATE          STIME    FMRI
online         18:28:28 svc:/application/nagios:default
online         19:28:03 svc:/network/http:apache24
I have restarted both services and the issue remains.
2) When trying to navigate using the left hand side menu, the CGI files are being downloaded instead of being executed.
https://prnt.sc/te8r1l
- Apache file /etc/apache2/2.4/httpd.conf seems to be configured with correct directives:
 AddHandler cgi-script .cgi
 Options Indexes FollowSymLinks ExecCGI
- I have checked the file /etc/apache2/2.4/conf.d/nagios.conf that also has the ExecCGI option:
   Options ExecCGI			<<<<<<<<<<<<<<<<<<
   AllowOverride None
   <IfVersion >= 2.3>
      <RequireAll>
         Require all granted
Could anyone please assist to investigate what is causing both issues ?
Kind Regards,
chedaille
Re: Nagios 4.4.5 fresh install not working on Solaris 11.4
Post by chedaille »
I have finally resolved this on my own. I "simply" forgot to uncomment the following lines in /etc/apache2/2.4/httpd.conf
        LoadModule cgid_module libexec/mod_cgid.so
        LoadModule cgi_module libexec/mod_cgi.so
Both issues are now solved.
chedaille wrote:Hello,
Glad to hear you have them resolved!
Locking thread
