Greetings to all, first of all I apologize for the possible poor writing of the post and for my level of English.
I have a problem when using a Powershell script that allows me to validate the status of windows backups
made with the feature "Windows server backups" or wbadmin.
This is the link where I found this script
https://github.com/DemisR/check_winbulog
In essence, what the script does is validate the status of the last Windows server backup and indicate the date of said copy.
After performing all the configuration and when validating the service from Nagios Core it throws me the error of UNKNOWN
and with the Status Information: Unknown command (s): check_backup
I attach the modified script to my need and the configuration files of my Nagios Core server
Script PowerShell
$returnStateOK = 0
$returnStateWarning = 1
$returnStateCritical = 2
$returnStateUnknown = 3
$status = get-wbjob -previous 1
$hresult=$status.errordescription
if ($status.hresult -eq "0" -and !$hresult)
$message = "OK - Last backup success at {0} " -f $status.endtime
Write-Host $message
exit $returnStateOK
elseif ($hresult.Contains("warnings"))
$message = "WARNING - {0} " -f $status.endtime
Write-Host $message
exit $returnStateWarning
else
$message = "CRITICAL - Last backup failed {0} " -f $status.endtime
Write-Host $message
exit $returnStateCritical
if ($runningstatus.CurrentOperation)
{$message = $runningstatus.CurrentOperation}
$message = "UNKNOW - Not found backups events"
exit $returnStateUnknownCode: Select all
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; PASSWORD - Password used to authenticate against server
password = XXXXX
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = XXXXX
[/settings/NRPE/server]
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket. default-workarounds Various workarounds for what I understand to be broken ssl implementations no-sslv2 Do not use the SSLv2 protocol. no-sslv3 Do not use the SSLv3 protocol. no-tlsv1 Do not use the TLSv1 protocol. single-dh-use Always create a new key when using temporary/ephemeral DH parameters. This option must be used to prevent small subgroup attacks, when the DH parameters were not generated using "strong" primes (e.g. when using DSA-parameters).
ssl options =
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket. none The server will not send a client certificate request to the client, so the client will not send a certificate. peer The server sends a client certificate request to the client and the certificate returned (if any) is checked. fail-if-no-cert if the client did not return a certificate, the TLS/SSL handshake is immediately terminated. This flag must be used together with peer. peer-cert Alias for peer and fail-if-no-cert. workarounds Various bug workarounds. single Always create a new key when using tmp_dh parameters. client-once Only request a client certificate on the initial TLS/SSL handshake. This flag must be used together with verify-peer
verify mode = none
; ALLOW INSECURE CHIPHERS and ENCRYPTION - Only enable this if you are using legacy check_nrpe client.
insecure = true
allow arguments = true
[/modules]
; NRPEServer - A server that listens for incoming NRPE connection and processes incoming requests.
NRPEServer = 1
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; NSClientServer - A server that listens for incoming check_nt connection and processes incoming requests.
NSClientServer = 1
; CheckExternalScripts - Execute external scripts
CheckExternalScripts = 1
; CheckHelpers - Various helper function to extend other checks.
CheckHelpers = 1
; CheckEventLog - Check for errors and warnings in the event log.
CheckEventLog = 1
; CheckNSCP - Use this module to check the healt and status of NSClient++ it self
CheckNSCP = 1
; CheckDisk - CheckDisk can check various file and disk related things.
CheckDisk = 1
CheckExternalScripts = enabled
; A list of templates for wrapped scripts.
%SCRIPT% will be replaced by the actual script an %ARGS% will be replaced by any given arguments.
; POWERSHELL WRAPPING -
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
; BATCH FILE WRAPPING -
bat = scripts\\%SCRIPT% %ARGS%
; VISUAL BASIC WRAPPING -
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
; A list of aliases available.
An alias is an internal command that has been predefined to provide a single command without arguments. Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = check_drivesize
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = check_drivesize
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = check_tasksched show-all "syntax=${title}: ${exit_code}" "crit=exit_code ne 0"
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = check_process "process=$ARG1$" "crit=state != 'stopped'"
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = check_service
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = check_process "filter=is_hung" "crit=count>0"
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = check_process "process=$ARG1$" "warn=count > $ARG2$" "crit=count > $ARG3$"
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = check_process "process=$ARG1$" "crit=state != 'started'"
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = check_memory
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = check_files "path=$ARG1$" "crit=size > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${size}" max-dir-depth=10
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = check_drivesize
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = check_cpu "warn=load > $ARG1$" "crit=load > $ARG2$" time=5m time=1m time=30s
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = check_files "path=$ARG1$" "crit=written > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${written}" max-dir-depth=10
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = check_cpu
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = check_eventlog
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = check_service "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = check_uptime
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = check_drivesize
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = check_tasksched show-all "filter=title eq '$ARG1$'" "detail-syntax=${title} (${exit_code})" "crit=exit_code ne 0"
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = check_tasksched "filter=status = 'running'" "detail-syntax=${title} (${most_recent_run_time})" "crit=most_recent_run_time < -$ARG1$"
[/settings/external scripts/wrappings]
check_backup=cmd /c echo scripts\check_backup.ps1; exit$LastExitCode | powershell.exe -command -
command_name check_windows_backup
command_line $USER1$/check_nrpe -2 -H $HOSTADDRESS$ -c check_backup
#}Service definition
host_name XXXX
check_command check_windows_backup
notification_interval 0
check_interval 1440
