I was trying to do an manual installation of our system to Centos 8, I ran into a problem
The message that it stopped on was
Collecting pymssql<3
I did find this web page, it may be unrelated
https://github.com/pymssql/pymssql/issues/668
Hoping you can assist.
Manual full install on Centos 8
Re: Manual full install on Centos 8
Could you attach the full install.log from the installation directory?
As requested the install log file
Thanks Again
Thanks Again
It looks like the system is having problems reaching out to install the package from pip
Is this system behind a proxy?
Yes, the system is behind a proxy. Have I missed one, I have done yum, wget and curl?
Regards
Regards
I had added entries to files yum.conf, wgetrc and a alias for curl to use the proxy.
Is this a better approach?
export http_proxy=http://<IP Address>:<Port>/
export https_proxy=https://<IP Address>:<Port>/
This appears to work to rectify the point where my issue started.
I have now manged to do a full install and restore of my existing system, still working through some issues there.
Terry
Terry
This is our recommended approach for use of proxies:
https://support.nagios.com/kb/article/n ... s-147.html
I am glad that you were able to complete the full install successfully. Please start a new thread for any issues that you might have with Nagios XI 5.7.1. Thanks!I have now manged to do a full install and restore of my existing system, still working through some issues there.
