Nagios Newbie stuck with error messages.
jerryroy1
Post by jerryroy1 »
I am a Brand new Nagios user. I have inherited it in my new Job. I am having trouble getting my server to run now after following this procedure to add an ASA firewall (see link below)
http://www.techspacekh.com/monitoring-c ... plication/
I am getting an error message as follows and am stuck. I am not sure what I am missing at the moment.
WARNING: The normal_check_interval attribute is deprecated and will be removed in future versions. Please use check_interval instead.
WARNING: The retry_check_interval attribute is deprecated and will be removed in future versions. Please use retry_interval instead.
Error: Template 'generic-switch' specified in host definition could not be not found (config file '/usr/local/nagios/etc/techspacekh/remotehosts/cisco-asa5510.cfg', starting on line 3)
Error: Invalid max_check_attempts value for host '389-01'
Error: Could not register host (config file '/usr/local/nagios/etc/techspacekh/hosts.cfg', starting on line 81)
I have attached my hosts.cfg and my cisco-asa5510.cfg file. Can someone point out my mistake?
Best regards,
Jerry the NagiosNewbie
cisco-asa5510.cfg
(1.87 KiB) Downloaded 217 times
generic-hostgroup.cfg
From the doc listed in the post
(79 Bytes) Downloaded 202 times
hosts.cfg
(11.27 KiB) Downloaded 216 times
