NNA can't resolve host IP
agpol07
Post by agpol07 »
There is one ip address in my network that is not resolved on NNA gui.
If i make a nslookup or ping the host name from cli it is resolved properly.
Re: NNA can't resolve host IP
It need to be able to do a reverse DNS lookup, if you run nslookup with the IP what do you get?
nslookup xxx.xxx.xxx.xxx
agpol07
Post by agpol07 »
[root@nagios /]# nslookup 10.2.2.20
Server:         10.2.3.16
Address:        10.2.3.16#53
20.2.2.10.in-addr.arpa  name = proxy1.XXXXXXXXXXXX.
[root@nagios /]#
[root@nagios /]# nslookup proxy1.XXXXXXXXXXXXX
Server:         10.2.3.16
Address: 10.2.2.20
ssax
Dreams In Code
Post by ssax »
What does your /etc/resolv.conf show?
cat /etc/resolv.conf
What does this output?
php -r 'echo gethostbyaddr("10.2.2.20")."\n";'
agpol07
Post by agpol07 »
ssax wrote:What does your /etc/resolv.conf show?
; generated by /sbin/dhclient-script
search MYDOMAIN
nameserver 10.2.3.16
nameserver 10.3.3.33
ssax wrote: What does this output?
proxy1.XXXXXXXXX
agpol07
Post by agpol07 »
I've tried everything from this thread, too.
https://support.nagios.com/forum/viewto ... 32&t=38274
But, with no luck..
agpol07
Post by agpol07 »
I'd like to mention that when i first set up NNA, the above resolutions didn't work.
Then i contacted DNS admin, and after he changed something everything worked fine from ssh(cli), but not from GUI.
ssax
Dreams In Code
Post by ssax »
I'm out of ideas. Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup so we can debug further:
https://support.nagios.com/tickets/
ssax
Dreams In Code
Post by ssax »
Locking thread, ticket received, we will continue support through the ticket.
If anyone else experiences this, run this command to delete the old cached item:
- Change X.X.X.X to the IP of the affected system
mysql -h 127.0.0.1 -unagiosna -pnagiosna nagiosna -e "delete from nagiosna_hostname_cache where ip='X.X.X.X';"
Then go view a report that contains it and it should re-cache the information.
