Hi ,
we are facing perl dependency issue in check_nwc_health plugin in centos .
Please check attached error detail and let us know how to resolve.
Note:- server doesn't have internet connection ,so we will upload package offline to server if required.
plugin issue
progressive.nagiosXI
plugin issue
benjaminsmith
Re: plugin issue
It's probably not installed in the correct path. Let's run the following to find the location of the Perl module on the server.
Reference:
perlmodinstall
locate MD5.pm
perlmodinstall
Re: plugin issue
Please check attachment plugin still showing perl error
benjaminsmith
Re: plugin issue
Ok, thanks for gathering up that info, this looks like the issue here:
See:
https://centos.pkgs.org/7/centos-sclo-r ... 4.rpm.html
and we tested the plugin here at it works with version 2.55, but not sure if that package is available for offline installation.Digest::MD5 object version 2.52 does not match bootstrap parameter 2.55 at /usr/lib64/perl5/DynaLoader.pm line 213.
See:
Re: plugin issue
Hi Benjamin,
Thanks for info , please close this thread now .
we tried in other centos 7 machine with same version , we cannot resolve this offline.
but in test machine after download dependency through yum issue resolved.
So we will done this after Internet availability on server .
Re: plugin issue
Greatprogressive.nagiosXI wrote:Hi Benjamin,
closing thread
