How to change graph title
lilydalehs
Post by lilydalehs »
Hi All,
is there any way to change the title on graphs? I've tried setting the Display Name but that hasn't worked. A quick search of the forum revealed a feature request way back in 2016 so hopefully it's been implemented by now?
Cheers,
Chris.
Re: How to change graph title
Currently, you cannot change graph titles. I didn't see the feature request from 2016 that you mentioned. Do you have the task ID of this feature request by chance? I can check the status of the task for you.
lilydalehs
Hi lmiltchev,
https://github.com/NagiosEnterprises/ncpa/issues/629
that was the feature request I was referring to.
Cheers,
Chris.
Oh, this is posted as a NCPA feature request on GitHub... I was looking through the internal XI feature request tasks in our system.
I don't have an ETA for this FR. The decision to implement the enhancement is at the discretion of our development team. If it gets implemented, it would show up in the NCPA change log. You can check it out once in a while to see if the feature has been added:
https://github.com/NagiosEnterprises/nc ... HANGES.rst
