Not able to download 5.7.1 software
ITOMB_IMT
Post by ITOMB_IMT »
Good Morning,
I am trying to download 5.7.1 software from nagios repo. but i couldn't able to download because a malware has been detected in the rpm. our organization scans the software before downloading, and McAfee is blocking to download the software. Any thoughts on to download would be appericated.
jweijters
Re: Not able to download 5.7.1 software
Post by jweijters »
You don't want to use the buggy 5.7.1 version !
use the new 5.7.2
https://www.nagios.com/downloads/nagios-xi/change-log/
just download the latest version:
wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
ITOMB_IMT
Post by ITOMB_IMT »
Thanks for your reply. I dont see latest version in nagios.repo.com, I am looking for an offline install.
ISSB_MAOST wrote:Thanks for your reply. I dont see latest version in nagios.repo.com, I am looking for an offline install.
5.7.2 offline version is currently being worked on and should be available in the next week.. as for the McAffee error, looks like a false positive to me.
ITOMB_IMT
Post by ITOMB_IMT »
I tried to download offline install Nagios XI 5.7.2 but antivirus software is blocking it, saying malware detected. Please see attached error.
ISSB_MAOST wrote:I tried to download offline install Nagios XI 5.7.2 but antivirus software is blocking it, saying malware detected. Please see attached error.
This has to be a false positive, I would reach out to McAffee.
ITOMB_IMT
Post by ITOMB_IMT »
Ok, Thanks. Can you please change our user name from ISSB_MAOST to ITOMB_IMT.
ITOMB_IMT wrote:Ok, Thanks. Can you please change our user name from ISSB_MAOST to ITOMB_IMT.
Done. Changed
