With respect to the "check_snmp" plugin -- from the help page "the -t (timeout flag) does the optional ":<timeout state>" can be a state integer (0,1,2,3) or a state string" does this mean that we can set the return state (ok, warning, critical, unknown) in the case of a timeout?
Second, can you confirm that the check snmp plugin doesn't return anything from the gui when given the -t flag? I checked it from the command line & when i remove the -t flag it returns the expected result.
check_snmp
Re: check_snmp
Nagios plugin docs-t, --timeout=INTEGER:<timeout state>
Seconds before connection times out (default: 10)
Optional ":<timeout state>" can be a state integer (0,1,2,3) or a state STRING
Yes, I believe the second argument for the -t flag determines what state will be returned, should the plugin timeout.
I should also mention that these values are read several times, and the final state is actually determined by a series of checks.
check_snmp man pagesNOTE the final timeout value is calculated using this formula: timeout_interval * retries + 5
Please see the documentation on state types if you are not familiar with this logic.
Nagios state types
I can confirm that the -t flag works when I change it in the GUI. I get the following output.
[[email protected] ~]$ /usr/local/nagios/libexec/check_snmp -H <IP address> -o 'sysUpTime.0' -C '<community string>' -P 2c -t 1
SNMP OK - Timeticks: (2886921348) 334 days, 3:13:33.48 | DISMAN-EVENT-MIB::sysUpTimeInstance=2886921348As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
