There were no buckets found. Verify your AWS credentials and
cobwebs
Post by cobwebs »
Hey,
I'm trying to add EC2 instances into the Nagios monitoring but getting "There were no buckets found. Verify your AWS credentials and try again."
I tried on different machine and it's worked perfectly, what's can be an issue?
benjaminsmith
Re: There were no buckets found. Verify your AWS credentials
Post by benjaminsmith »
Hi @cobwebs,
Definitely some type of authentication issue here. Are using the static credentials file, it could be paths or permissions issue with that file?
