Hi
We are running in 5.5 NagiosXI in rhel 7, the service-perfdata file size is 48Gb, it's there a way to optimize on the size of the perf data? Increasing the diskevery time we reach the disk full if /usr is not ideal.
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
service_perfdata_file=/usr/local/nagios/var/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$\tLONGSERVICEOUTPUT::$LONGSERVICEOUTPUT$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
# host performance data
host_perfdata_file=/usr/local/nagios/var/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$\tLONGHOSTOUTPUT::$LONGHOSTOUTPUT$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
Service Perf Data too big
benjaminsmith
Re: Service Perf Data too big
HI,
How many current hosts and services are you monitoring in your environment? The RRD files stay the same size and do not get large as time goes by.
You may have old hosts and services, and those files could be deleted to save space.
Also, there is a Deadpool processor in Nagios XI and a setting for Removing performance data files (RRDs) upon host/service deletion.
How To Use Deadpool In Nagios XI
/usr/local/nagios/share/perfdata/<hostname>/<servicename>.rrd
