NCPA_PLUGIN
yybadrou
NCPA_PLUGIN
Post by yybadrou »
I am monitoring a windows host using NAGIOS XI and NCPA Client.
Inside this machine I have a software called KepServer with a LICENCE.
I have coded a python script (check_kepserver_licence) that once it's executed on this windows host, it returns if the licence is expired or up-to-date.
This script takes three arguments related to Kepware Server.
I want to know how can I have this information automatically on my NAGIOS GUI ? I don't know how can I configure my ncpa.cfg file and what command in /usr/local/nagios/libexec repository I have to use ? is It check_xi_ncpa or check_nrpe, do I have to create a new command or do I have a solution to execute my python script directly from Nagios Server?
Thank you so much
jbrunkow
Re: NCPA_PLUGIN
Post by jbrunkow »
Please see here:
https://www.nagios.org/ncpa/getting-sta ... ive-checks
And here:
https://www.nagios.org/ncpa/help.php#ap ... es-plugins
You should be able to use Configure > Configuration Wizards > NCPA and setup the plugin at the bottom.
See here:
Let us know if you have any questions.
Thank you!
