Separate Source IP and Source Hostname columns
solarmon
Post by solarmon »
In the top talkers table there is only the "Soure Hostname" column with either the IP address or the resolved hostname in it (with the IP address appearing as hover text).
Is there any way to have "Source IP" and "Source Hostname" as separate columns shown?
Thank you!
Re: Separate Source IP and Source Hostname columns
There is now a way to display both the Hostname and IP address in a source on the NNA server.
I can submit a feature request on your behalf if you'd like. Please keep in mind that the decision to implement the enhancement is at the sole discretion of our development team.
solarmon
Post by solarmon »
@tgriep
Yes, please submit the feature request. Even if it is just a user customisable option, that is fine. It just helps seeing both IP and DNS address on the same page. Being able to sort/ordering by the IP and hostname columns is also useful.
Thank you.
I did put in a feature request for this but we do not have a schedule on when or if it will be added.
