Error with Quota thresholds
Srinija544
Post by Srinija544 »
Hello All,
We have a quote service where the threshold values are configured as warn-10 and crit-5.
Even 79.83% is used, we are getting critical alerts which is wrong.
Please find the attached script and help me in resolving this alert.
Check-command:
check_quota_prophet_data_non_prod=check_quota.ps1 -Path "E:\Shares\PROPHET_DATA_NON_PROD" -Warn 5 -Crit 3
Thanks in Advance.
Srinija.
Quota Script.txt
(1.72 KiB) Downloaded 154 times
benjaminsmith
Re: Error with Quota thresholds
Post by benjaminsmith »
HI,
I would recommend printing out some of the values in your script, the likely case here is that the script is not parsing/computing the space correctly.
try {
$gbUsage = "{0:n2} GB" -f ($quotaObject.Usage / 1GB)
$gbLimit = "{0:n2} GB" -f ($quotaObject.Size / 1GB)
$percentUsed = "{0:n2}" -f ($quotaObject.Usage / $quotaObject.Size * 100)
$percentFree = "{0:n2}" -f (100 - $quotaObject.Usage / $quotaObject.Size * 100)
$perfData = "usage=$($quotaObject.Usage)B;$warn;$crit;0; limit=$($quotaObject.Size)B;;;;"
Also, you can probably achieve a similar check using the NCPA agent. Take a look at the API documentation:
https://www.nagios.org/ncpa/help.php#api-modules-disk
Let me know if that's an option.
Benjamin
srinija1994
Post by srinija1994 »
HI Benjamin,
Thanks for your response.
I have checked the attached URL but unfortunately it doesn't match our issue.
The drives size is not capturing correctly with the any scripts provided.
could you please let me know any other option for this?
Regards,
Srinija.
srinija1994
Hi All,
Unable to get the correct space details from the attached script.
Can any one please help me on this issue.
Thanks in Advance.
Srinija.
