Hi Support team.
We are currently running NRPE v2 on the customer host and they have a requirement to upgrade the NRPE v3.
Can you help point me the step by step guide on how do we achieve that.
Base on the thread that i read, It need to be manually compile for AIX version 7.1 and above.
I found this thread https://support.nagios.com/forum/viewto ... f=6&t=8979 but not sure if its for v3 or version 2.
The post was at year 2013.
NRPE v3 for AIX 7.1
benjaminsmith
Re: NRPE v3 for AIX 7.1
It looks like that thread would be for version 2 as version 3 was released a few years later. We currently do not have official instructions for AIX 7.x with NRPE, those are now available for our newer cross-platform agent, NCPA.
https://www.nagios.org/ncpa/#downloads
That said, assuming you have all the build requirements on the server, you can try to compile it from the source. Take a look a the following KB article for more details.
https://support.nagios.com/kb/article.php?id=515
safuanmansor
We will test it and get back if there is any issue that we encounter.
benjaminsmith
HI,
Sounds good.We will test it and get back if there is any issue that we encounter.
