Issue with growing log files
dshearon
Post by dshearon »
We received a low disk space alert for our XI server and upon investigation it appears the log files have grown to 250+GB. Any advice on how to troubleshoot the cause would be greatly appreciated. I attached a screen cap showing the logs files in question.
benjaminsmith
Re: Issue with growing log files
Post by benjaminsmith »
Hi @dshearon,
Nagios XI uses the logrotate program to handle compression and archiving of the log files in /usr/local/nagiosxi/var. This is set up as a daily cron ( see /etc/cron.daily ).
Check to see if cron is running on the server:
systemctl status crond
It's likely the cron job is not running or you have some kind of permissions issues. Please search or post the cron log in /var/log/cron to determine if this program is running or other related errors.
Let us know what you find out.
dshearon
Post by dshearon »
I attached a screen cap of the service running and the cron log file. I didn't notice anything that stood out but I may be missing something.
benjaminsmith
Hi @dshearon,
Thank you for the log. Logrotate is running.
Jul 27 03:36:01 cltisvcorpmon01 run-parts(/etc/cron.daily)[227736]: starting logrotate
Jul 27 03:36:01 cltisvcorpmon01 run-parts(/etc/cron.daily)[227775]: finished logrotate
Let's manually run it in debug mode, and post the output to the thread, it may be skipping over those directories.
logrotate -d /etc/logrotate.d/nagiosxi
dshearon
Post by dshearon »
Output is below, under that is the current owner/group of the file in question
[root@cltisvcorpmon01 ~]# logrotate -d /etc/logrotate.d/nagiosxi
Ignoring /etc/logrotate.d/nagiosxi because the file owner is wrong (should be root).
Allocating hash table for state file, size 15360 B
[root@cltisvcorpmon01 logrotate.d]# ls -l nagiosxi
-rw-r--r--. 1 nagios users 389 Dec 5 2017 nagiosxi
benjaminsmith
HI,
Interesting. What version of Nagios XI are you using, this is what I have on my 5.7.2 test server:
[root@localhost cron.d]# ls -l  /etc/logrotate.d/nagiosxi
-rw-r--r--. 1 root root 605 Jul 24 16:30 /etc/logrotate.d/nagiosxi
Try changing it back to root and 644, and then run it manually in debug mode again.
chmod 644  /etc/logrotate.d/nagiosxi
chown root:root /etc/logrotate.d/nagiosxi
dshearon
Post by dshearon »
We're on version 5.6.1 right now with plans to upgrade to 5.7 once we get the disk space back.
I reset permissions and manually ran the job, output is below.
Handling 3 logs
rotating pattern: /usr/local/nagiosxi/var/*log 5242880 bytes (1 rotations)
empty log files are not rotated, old logs are removed
considering log /usr/local/nagiosxi/var/cleaner.log
error: skipping "/usr/local/nagiosxi/var/cleaner.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/cmdsubsys.log
error: skipping "/usr/local/nagiosxi/var/cmdsubsys.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/dbmaint.log
error: skipping "/usr/local/nagiosxi/var/dbmaint.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/deadpool.log
error: skipping "/usr/local/nagiosxi/var/deadpool.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/event_handler.log
error: skipping "/usr/local/nagiosxi/var/event_handler.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/eventman.log
error: skipping "/usr/local/nagiosxi/var/eventman.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/feedproc.log
error: skipping "/usr/local/nagiosxi/var/feedproc.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/load_url.log
error: skipping "/usr/local/nagiosxi/var/load_url.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/nom.log
error: skipping "/usr/local/nagiosxi/var/nom.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/perfdataproc.log
error: skipping "/usr/local/nagiosxi/var/perfdataproc.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/recurringdowntime.log
error: skipping "/usr/local/nagiosxi/var/recurringdowntime.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/reportengine.log
error: skipping "/usr/local/nagiosxi/var/reportengine.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/scheduledreporting.log
error: skipping "/usr/local/nagiosxi/var/scheduledreporting.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
considering log /usr/local/nagiosxi/var/sysstat.log
error: skipping "/usr/local/nagiosxi/var/sysstat.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
rotating pattern: /usr/local/nagiosxi/var/xidebug.log 104857600 bytes (1 rotations)
considering log /usr/local/nagiosxi/var/xidebug.log
error: skipping "/usr/local/nagiosxi/var/xidebug.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
rotating pattern: /usr/local/nagiosxi/var/xidebug.log.backtrace 104857600 bytes (1 rotations)
considering log /usr/local/nagiosxi/var/xidebug.log.backtrace
error: skipping "/usr/local/nagiosxi/var/xidebug.log.backtrace" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.
dshearon
Post by dshearon »
Here are the set permissions for that directory.
[root@cltisvcorpmon01 ~]# ls -l /usr/local/nagiosxi/
total 64
drwxr-xr-x 2 root nagios 308 Jul 24 2018 cron
drwxr-xr-x 4 root nagios 67 May 3 2019 etc
drwxr-xr-x 19 root nagios 4096 May 1 2018 html
-rw-r--r-- 1 root nagios 0 Apr 23 2015 is.installed
drwxr-xr-x 3 root nagios 25 Apr 23 2015 nom
drwxr-xr-x 4 root nagios 4096 May 3 2019 scripts
drwsrwsr-x 4 root nagios 32768 Jul 10 11:45 tmp
drwxr-xr-x 2 root nagios 4096 Dec 5 2017 tools
drwxrwxr-x 7 root nagios 4096 Jul 30 15:47 var
ssax
Dreams In Code
Post by ssax »
Please attach this file:
We'll need to add "su root nagios" OR "su nagios nagios" to the /etc/logrotate.d/nagiosxi definitions for each.
Like this:
https://support.microfocus.com/kb/doc.php?id=7005219
dshearon
Post by dshearon »
The requested file is attached. I needed to add the .txt extension to allow the attachment.
