Apply configuration from tools
chrtap
Post by chrtap »
We use a "Common Tools" that run a script how modify SMS phone number for a special contact.
To avoid this modification to be removed by a snapshot rollback, I search a way to "Apply Configuration" from the "Common Tools".
I tried to add "reconfigure_nagios.sh" to my script but it doesn't work because the script is running as apache's user and don't have right to do that.
What can I do ?
Regards.
Re: Apply configuration from tools
You should be able to make a call to the following URL in the page that loads in the Common Tools and it will complete an Apply Configuration
/nagiosxi/includes/components/nagioscorecfg/applyconfig.php?cmd=&continue=
chrtap
Post by chrtap »
Hello Scott,
Big thanks to you.
I have had some difficulties to find the correct syntax. The originals script is a shell script who generates an HTML page.
Finlay, I make an ifram :
echo '<iframe title="Snapshot" width=500 height=200 src="/nagiosxi/includes/components/nagioscorecfg/applyconfig.php?cmd=confirm"></iframe>'
Regards
Christian
chrtap wrote:Hello Scott,
Big thanks to you.
Regards
Christian
Great
May we mark this resolved?
