delay to refresh
fsodah
delay to refresh
Post by fsodah »
I have noticed that after the upgrade to version 5.7.1
Sometimes it can take 3 - 5 seconds to show the value correct after modification or to show correctly on screen even also after going 5.7.2 too
Just an observation.
benjaminsmith
Re: delay to refresh
Post by benjaminsmith »
Thanks for letting us know. For clarification, can provide more details on 'modifications', are these changes to the configurations? It does normally take some time for it to write out the new configuration files.
fsodah
Post by fsodah »
I will keep monitoring this behavior for the next days .... as you said it might takes time to write the config .... however i ll keep monitoring it.
One thing you could try is to check the Nagios Core interface after making your mods.
http://x.x.x.x/nagios
This way, you would see if the issue is with Nagios Core or with NDO. If Nagios Core shows the "updated" objects right away, but XI doesn't, most likely this is a NDO issue, and needs to be looked into.
fsodah
Post by fsodah »
I made up my mind ... I think after the upgrade to the latest version ... i dont see this delay any more ....
Thank you ... close this ticket
Great! I you have any further questions/issues, please start a new thread. Thank you!
