Bandwidth usage table lags by >24 hours
GldRush98
Post by GldRush98 »
I'm curious as to why this table data lags behind the actual data Nagios has?
You can see the Day 1 column is populated, but even though there is data for Day 2 as well as Day 3 (today) in the graph, this data is not represented in the text table. It seems this table constantly lags behind by the current day plus the previous day never being populated.
Is there a reason for this?
Is there any way to make this table accurately reflect the currently known data amounts?
Prod XI: Debian 12 - Nagios XI 2026R1.2
Dev XI: Debian 12 - Nagios XI 2026R1.2
jbrunkow
Re: Bandwidth usage table lags by >24 hours
Post by jbrunkow »
Nagios spools performance data into small files which get moved around and processed. Sometimes a problem can arise which stops the files from being processed and they begin to spool up.
Troubleshooting Graphs
Can you see whether some performance data has spooled up on that server?
ls /usr/local/nagios/var/spool/perfdata/ | wc -l
ls /usr/local/nagios/var/spool/xidpe/ | wc -l
You can clear this spool to see if the process speeds up thereafter.
find /usr/local/nagios/var/spool/perfdata/ -type f -delete
We can change the way that Nagios processes performance data by editing the relevant configuration file.
/usr/local/nagios/etc/pnp/process_perfdata.cfg
It never hurts to send ( PM ) us a profile either! We can find lots of information about your system in there. You can download the profile by navigating to System Profile under System Config on the left pane > and clicking the Download Profile button on that page.
GldRush98
Post by GldRush98 »
Nothing is backed up as far as perfdata goes. As you can see the perfdata graph is accurate and up to date.
[root@nagios ~]# ls /usr/local/nagios/var/spool/perfdata/ | wc -l
0
[root@nagios ~]# ls /usr/local/nagios/var/spool/xidpe/ | wc -l
0
[root@nagios ~]# ll /usr/local/nagios/var/spool/perfdata/
total 0
You know what... now that I'm looking at more data, everything in the usage table (the text table) appears off a day compared to the perfdata graph itself. Assuming the graph is right, which I believe it is because it is showing up-to-current data... the data spikes clearly in the graph are NOT lining up to where the high numbers are in the text table. Everything is shifted a day behind in the table
This text table is inaccurate. It could be the php timezone shifting things off, or it might be a full 24 hours off, I am not positive, but something is causing the data in the table to be wrong when compared to the actual perfdata represented by the highchart.
GldRush98
Post by GldRush98 »
With some more experimenting I believe that the php timezone offset is throwing the text table's calculations off. There should probably be a bug report filed for this as it appears that if php's current timezone is accounted for, data looks to shift to the correct days and even the previous day's data shows up in my table. (today's data does not, but I don't necessarily expect it to until the day is "complete")
Also, June is spelled wrong when the month array is set up:
/* Convert a month number to a month name */
function monthname($no)
    $names = array(1 => 'January', 'February', 'March', 'April', 'May', 'Junr', 'July', 'August', 'September', 'October', 'November', 'December');
    return $names[$no];
} //function monthname($no)
jbrunkow
Post by jbrunkow »
Alright, I have submitted a bug report for this issue. I will pass that information along to our developers.
Forgive me if this is a bit obvious. But have you double checked that all of the time zone settings are correct on your XI instance?
Changing The System Time
GldRush98
Post by GldRush98 »
Yes, I have double checked all of the various timezone settings and all are set and showing correctly for my timezone.
jbrunkow
Post by jbrunkow »
Thank you for confirming that.
Our developers confirmed that report is working as intended. The reason this data lags behind is that our software uses a round robin database to average this data over time, so that it does not become too large to manage.
RRDtool
