Log Monitoring on LINUX/AIX OS
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
Kindly let us know the complete procedure for Log Monitoirng on LINUX/AIX OS.
We have already installed NRPE Agent on those above OS MAchines.
Thanks & Regards,
I2MP Team.
jbrunkow
Re: Log Monitoring on LINUX/AIX OS
Post by jbrunkow »
You should be able to run the check log plugin against those machines.
/usr/local/nagios/libexec/check_log
This plugin is probably installed by default. To use it, define a command by navigating to Configure using the top bar > click Core Config Manager under Advanced Configuration on the left pane > then click >_Commands under Commands > and click the + Add New button on that page.
Managing Plugins in Nagios XI
