Problem with Service Checks in 5.7.2 UI
provitech
Post by provitech »
Upgraded to 5.7.2 yesterday. Just started messing around with editing service checks... It appears whatever service check I edit, all the hosts attached to it get cleared out after saving... This happens for creating a new service check, cloning a service check or editing a service check, no matter what I do, the hosts on the service check always go back to 0 after I save and go back into it, then I can't apply config obviously because it complains about no hosts being assigned to those service checks
Is this a known bug with the latest XI 5.7.2 ?
provitech
Re: Problem with Service Checks in 5.7.2 UI
Post by provitech »
This was resolved by doing the following:
https://support.nagios.com/kb/article/n ... s-780.html
benjaminsmith
Post by benjaminsmith »
Hi @provitech,
Happy to hear you got it fixed!
Thanks for sharing the solution as well, we'll go ahead and close this out.
