this is a new turn up of XI trial.
all host have nsclient++ and most now have NCPA installed.
This turn up was created following the migration instructions from nagios Core to XI.
I am seeing could not fetch from server across the board for ALL host and related services.
I have reviewed in depth the support forums, google docs and all other things I've come across trying to resolve this with NO Luck.
could not fetch
Re: could not fetch
Hey @statusuknown03!
Welcome to the forum.
Did anything about the server change when you upgraded it to XI? Did the IP address change?
Have you tested the checks from the command line?
You may also want to try pinging the hosts from your XI instance as well. Just to see if they are routable.
What step did you get stuck on in the guide?
Migrating core to XI
It never hurts to send ( PM ) us a profile either! We can find lots of information about your system in there. You can download the profile by navigating to System Profile under System Config on the left pane > and clicking the Download Profile button on that page.
/usr/local/nagios/libexec/check_ncpa.pyCode: Select all
ping -c 1 <IP address>Migrating core to XI
Re: could not fetch
Locking thread, ticket received, we will continue support through the ticket.
Thank you!
Thank you!
