Hello Team,
We have installed NCPA agent on our Windows servers and NCPA service is also running fine. We checked the config files as well, but it is correct as expected.
When trying to configure monitoring, we are getting below error:
Unable to contact server at https://10.1.200.7:5693/testconnect/?to ... Lhoub.2018.
Now, here the token value in above error is not correct. We have verified the token values already and it is correct. I am not sure why this is coming.
Please help us on the same.
Bad token error
Bad token error
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: Bad token error
https://10.1.200.7:5693/testconnect/?token=CH%40Lhoub.2018You can also increase the log level of ncpa_listener to debug, and see if the token is being interpreted properly when you run the test connection.
The only other thing to note is that NCPA is meant to run on Windows Vista/Server 2008 and forward. It may behave strangely on Windows Server 2003.
Re: Bad token error
Thanks for your reply!!
Could you please help me to understand where I can increase the log level of ncpa_listener to debug?
I am not sure about the particular path/file.
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: Bad token error
In your ncpa.cfg file. Usually this lives in C:\Program Files (x86)\Nagios\ncpa\etc\. There are two sections for log level. One is for the listener, and one is for the passive service. You want the listener log level increased from warning to debug.
Once you've made the change, restart the NCPA Listener service, try to execute a service check from Nagios XI, and then check the NCPA log file on the server, which will be at C:\Program Files (x86)\Nagios\ncpa\var\log\
# Listener logging file level, location, and the PID location
# Default: loglevel = info (debug, info, warning, error)
# Default: logfile = var/log/ncpa_listener.log
# Default: pidfile = var/run/ncpa_listener.pid (leave listener in pid file name)
loglevel = debug
pidfile = var/run/ncpa_listener.pidAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Re: Bad token error
We noticed that the ncpa service itself is not running on the server.
We re-installed the ncpa agent, did the changes as per your suggestion. But still we are unable to see the ncpa service.
What could be the reason for it?
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: Bad token error
Potentially. Let's troubleshoot this in the other thread, and if we can confirm that the service is working as expected, but you still get the token error, we can come back to this one.
