Because of whom I work for, all servers in my environment are without internet access. What I typically do is pull down what I need from the internet on my workstation (I do have access there), then transfer the .rpm, .gz ... files to where they are needed in the application. I found the post where it describes how to update logserver offline. I ran all the changes (mostly sed's) and still got errors when I tried running update (see below)
Unable to download data from https://rubygems.org/ - Socket closed (https://api.rubygems.org/specs.4.8.gz)
ERROR: Installation aborted, verification failed for logstash-filter-geoip.4.0.4-java.gem
INSTALL: wkhtmltox is being installed...
--2020-08-06 12:35:14-- https://assets.nagios.com/downloads/nag ... x86_64.rpm
Resolving assets.nagios.com (assets.nagios.com)... 72.14.181.71, 2600
Connecting to assets.nagios.com (assets.nagios.com)|72.14.181.71|:443... connected.
Unable to establish SSL connection.
I was able to pull down speck.4.8.gz. However, I could not find wkhtmltox-0.12.1.3.el7.x86_64.rpm anwhere. On github the closest version I could find was wkhtmltox-0.12.1.2. How do I obtain a copy of this rpm?
Thank you.
Bruce
