i currently have some physical palalto appliances monitored in nagios through snmp and they are worjing fine, however i tried adding a vitual one from azure today and i ran into some errors. its looking like an snmp issue but am sure the configuration is right but am not getting any response when i try the wizard and also on the command line, please see results below when i try to query hosts
@dximonp1 ~]# /usr/bin/cfgmaker --show-op-down --noreversedns --zero-speed '100000000' '!plut0@172.19.20.232 :161::::2'
Subroutine SNMP_Session::pack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
at /usr/bin/../lib/mrtg2/SNMP_Session.pm line 149.
Subroutine SNMP_Session::unpack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
Subroutine SNMPv1_Session::pack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
at /usr/bin/../lib/mrtg2/SNMP_Session.pm line 604.
Subroutine SNMPv1_Session::unpack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
--base: Get Device Info on !plut0@172.19.20.232 :161::::2
SNMP Error:
no response received
SNMPv2c_Session (remote host: "172.19.20.232 " [172.19.20.232].161)
community: "!plut0"
request ID: -584935054
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at /usr/bin/../lib/mrtg2/SNMP_util.pm line 651.
SNMPWALK Problem for 1.3.6.1.2.1.1 on !plut0@172.19.20.232 :161::::2:v4only
at /usr/bin/cfgmaker line 951.
WARNING: Skipping !plut0@172.19.20.232 :161::::2 as no info could be retrieved
Use of uninitialized value $comment_sysdescr in substitution (s///) at /usr/bin/cfgmaker line 379.
Use of uninitialized value $sysname in concatenation (.) or string at /usr/bin/cfgmaker line 412.
Use of uninitialized value $comment_sysdescr in concatenation (.) or string at /usr/bin/cfgmaker line 412.
Use of uninitialized value $syscontact in concatenation (.) or string at /usr/bin/cfgmaker line 412.
Use of uninitialized value $syslocation in concatenation (.) or string at /usr/bin/cfgmaker line 412.
# Created by
# /usr/bin/cfgmaker --show-op-down --noreversedns --zero-speed 100000000 "!plut0@172.19.20.232 :161::::2"
### Global Config Options
# for UNIX
# WorkDir: /home/http/mrtg
# or for NT
# WorkDir: c:\mrtgdata
### Global Defaults
# to get bits instead of bytes and graphs growing to the right
# Options[_]: growright, bits
EnableIPv6: no
# System:
# Description:
# Contact:
# Location:
adding palalto azure cloud appliance to nagios
Re: adding palalto azure cloud appliance to nagios
You may need to install nmap first:
or
but what is the output of these commands when run on the XI command line:
yum -y install nmap
apt-get install nmap
nmap 172.19.20.232 -p 161 -sU
snmpwalk -v2c -c '!plut0' 172.19.20.232 1.3.6.1.2.1.1
nmap was already installed in my system, if i am correct do u mean nmap on the virtual host or nagios?
or RHN Classic support will be disabled.
[root@dximonp1 ~]# nmap 172.19.20.232 -p 161 -sU
Starting Nmap 6.47 ( http://nmap.org ) at 2020-08-12 12:10 CDT
Nmap scan report for 172.19.20.232
Host is up (0.052s latency).
PORT STATE SERVICE
161/udp open snmp
Nmap done: 1 IP address (1 host up) scanned in 0.27 seconds
[root@dximonp1 ~]# snmpwalk -v2c -c '!plut0' 172.19.20.232 1.3.6.1.2.1.1
Timeout: No Response from 172.19.20.232
[root@dximonp1 ~]#
PORT STATE SERVICE
161/udp open snmp
[root@dximonp1 ~]#
Maybe try a different community string besides '!plut0'. Can you use 'public'?
Are you sure the requests are making it to their intended destination? If so, are they taking the same route back to the XI machine? Running a tcpdump on the XI command line while you run the snmpwalk command again on another terminal window may show something useful:
or write it to a file for easy readability in wireshark:
tcpdump -s 0 -i any -nnX port 161 or icmp
tcpdump -s 0 -i any port 161 or icmp -w output.pcap
