Deadpool Regex exclusion options
seaward1983
Post by seaward1983 »
RHEL 7
V 5.7.2
Are you able to have deadpool to remove only "unknown" versus everything in a problem state?
jbrunkow
Re: Deadpool Regex exclusion options
Post by jbrunkow »
Problem states are “DOWN” for hosts and “CRITICAL” or “UNKNOWN” for services.
This logic is baked into that feature, it doesn't currently support filtering on just UNKNOWNs.
Exclusion Filters are used to exclude objects from the settings above. Exact string matches or PRCE regularexpressions can be used.
The Exclusion Filters are only for excepting a host or service from being added to the deadpool.
Deadpool in Nagios XI
If there is enough demand for a feature, we can submit a request to our developers to add it as a feature in a future release! :D
