I have my Nagios XI server and a set of equipement monitored thanks to the new agent NCPA. I really find it great and helpful.
In the documentation I read about active checks and how can we use the GET method to extract monitored data. as an example, in the following directory
/usr/local/nagios/libexec#./check_ncpa -H <<HOSTADDRESS>> -t mytoken -M '/cpu' -w 'value1 '-c 'value2' - How can we use a SET Method as an API request? and what can we modify using this SET Method ?
- If we talk security ? what is the possible vulnerability that this type of request can presents ? and how we can avoid it ?
Thank you
