check_logfiles
fsodah
check_logfiles
Post by fsodah »
how to get this done ,,, i need to sniff some pattern in diff log files from diff services... how to install and how can get this run from client and server side? Thanks in advance
jbrunkow
Re: check_logfiles
Post by jbrunkow »
You should be able to do so with the -q option of the check_logs plugin or by downloading and installing the check_logfiles plugin.
You can see the installation instructions here:
https://labs.consol.de/nagios/check_log ... stallation
Look in your libexec folder to see what plugins are present in XI.
cd /usr/local/nagios/libexec && ls
check_logfiles on GitHub
check_logfiles on Nagios Exchange
fsodah
Re: check_logfiles
Post by fsodah »
I have the following
[root@nagios libexec]# ls check_l*
check_last_logs.pl  check_ldap  check_ldaps  check_load  check_log
[root@nagios libexec]# ls -al check_l*
-rwxrwxr-x 1 apache nagios   1811 Sep 24  2019 check_last_logs.pl
-rwxrwxr-x 1 apache nagios 227968 Jun 27 10:32 check_ldap
lrwxrwxrwx 1 apache nagios     10 Jun 27 10:32 check_ldaps -> check_ldap
-rwxrwxr-x 1 apache nagios 169704 Jun 27 10:32 check_load
-rwxrwxr-x 1 apache nagios   7068 Jun 27 10:32 check_log
fsodah
Re: check_logfiles
Post by fsodah »
If i do “configure, make and install” would be this normally for my nagios server without missing with the integrity of the system
and copy it to /usr/local/nagios/libexec and then chmod +x it and also chown nagios:nagios it.
jbrunkow
Re: check_logfiles
Post by jbrunkow »
Yeah, can run the following commands to configure and then install it.
cd /tmp
wget https://labs.consol.de/assets/downloads/nagios/check_logfiles-3.12.tar.gz
tar zxf check_logfiles-3.12.tar.gz
cd check_logfiles-3.12
./configure
make all
make install
It will install in the default directory, so I don't think you have to move it there.
fsodah
Re: check_logfiles
Post by fsodah »
Done ... please close it
Re: check_logfiles
fsodah wrote:Done ... please close it
Great
Locking thread
