Need help with Meraki Dashboard monitoring with Nagios XI
capgemtools
Post by capgemtools »
Hello Support,
We are trying to monitor CISCO Meraki devices with NagiosXI. We are looking for a documentation for getting this monitored using API option. If this is possible in NagiosXI, please help us with the details.
Sandeep
Supriya
jbrunkow
Re: Need help with Meraki Dashboard monitoring with Nagios X
Post by jbrunkow »
Hello @capgemtools!
Welcome to the forum. :D
I see one plugin on the Nagios Exchange for monitoring Cisco Meraki devices specifically. Follow the link below to check it out, and let us know if that works for you! :)
Meraki - Check Device Status
If you are unsure of how to implement a new plugin in your XI instance, follow the link below.
Managing Plugins In Nagios XI
If the plugin on the Exchange does not suit your needs, you may be able to monitor the device via SNMP if you can find the relevant OID or MIBs for what you would like to monitor.
Integrating SNMP Traps With Nagios XI
