Installation problem
I'm trying to install nagios core onto centos8. I've followed the instructions in the docs and got as far as unzipping the tarball, but when I try this, I get an error message saying that it's not a valid gzip
Re: Installation problem
Are you following the steps at https://support.nagios.com/kb/article/n ... .html#RHEL ?
You can verify the download by checking the md5sum of the file. The md5sum for the download is 75ded99ce9abfeffac01d5f0ed86702b:
Also verify the file type:
md5sum nagios-4.4.5.tar.gzCode: Select all
file nagios-4.4.5.tar.gzAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
