You may also want to try the check_logfiles plugin to see if that works better for you.
Need confirmation!! Do i need to install the above on both clients and server (Nagios) to sniff the patterns?
Logs
benjaminsmith
Re: Logs
The plugin would need to reside on the host where you intend to check the logs, you'll either have to use an agent like NCPA or check_by_ssh to run this on the host and return the results to Nagiso XI.
Let us know if you have more questions.
Re: Logs
Great!fsodah wrote:Done ... its clear now ... please close the ticket.
Locking thread
