hi team,
after new update of nagios XI i am trying to use ncpa agent for both windows and linux.
i am facing issue in monitoring below things.
NTP
TCP port
Monitoring using ncpa
Re: Monitoring using ncpa
NCPA can execute scripts following steps in https://support.nagios.com/kb/article/n ... a-722.html.
A good place to check for scripts/plugins would be the exchange. For example:
https://exchange.nagios.org/directory/P ... 29/details
https://exchange.nagios.org/directory/P ... nc/details
https://exchange.nagios.org/directory/P ... ll/details
https://exchange.nagios.org/directory/P ... ux/details
[email protected]
hi Thanks for updates,
windows scripts are working but for linux those are not working.
What kind of behavior or error are you seeing? What were the exact steps you took?
[email protected]
getting library files missing, when we install nagios nre client it compiles many library files where in ncpa it wil not.
You may find you prefer the NRPE client which is valid, however I would point out that this client is deprecated - https://github.com/NagiosEnterprises/nrpe.
If you'd like to troubleshoot the issues you are seeing with NCPA, please provide more details including the steps you've taken, the plugin you're trying to run, and any error messages you may get.
